1990 K5 Battery Dying
Old May 27, 2010 | 05:08 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Default 1990 K5 Battery Dying
About an hour and a half ago, I took the Blazer for it's daily ride, not too far a 5-10 minute ride almost every day is what I've been doing. Anyway, I happened to look at the dash and the battery voltage gauge was pointing to 8 and the battery indicator light was also on. My driveway is a HUGE hill and the truck ALWAYS makes it up with barely any gas today I needed to floor it just to get up because the battery is dying (dead) My question is, if I use jumper cables to charge it from either one of my parent's cars 2004 Toyota Camry, 2009 Toyota RAV4, will the battery charge back, or do I have a better chance just running the truck for 10-15 minutes?
Thanks
Old May 27, 2010 | 05:51 PM
You do not want to charge a battery using jumper cables. It is way to fast of a charge. You need a charger.
You have to determine if your alternator is actually charging first.
Old May 27, 2010 | 05:54 PM
OK, how do I do that?
Old May 28, 2010 | 01:32 PM
rxm6's Avatar
rxm6 is on a distinguished road
Use a voltmeter. Charging voltage should be around 14.4vdc -- but don't quote me on that exact figure. Anywhere between 13.5vdc and 14.5vdc should be charging
Old May 29, 2010 | 11:26 AM
As of yesterday, the problem is now gone. I took a huge risk (because it's not registered and has no sticker) and went for a longer ride in the Blazer. On the way back to my house, I noticed that the battery indicator light had turned off and the voltage had increased. So i stopped on the side of the road and gave it a couple of not too high RPM revs and the voltage meter spiked up to 14 as opposed to 8. So the alternator does charge the battery.
Kayruss
Sep 28, 2011 12:49 PM
Wmac
May 7, 2007 06:11 PM
biggee247
Mar 29, 2006 12:51 PM
biggee247
Mar 22, 2006 11:21 PM
squirrel
Feb 26, 2006 08:24 PM
