leaf springs
Old Mar 18, 2009 | 01:35 PM
The kits are probably for a single axle. Seeing as how you have two different axles under your truck, that is how it should be.
Old Mar 18, 2009 | 01:49 PM
bignate74's Avatar
bignate74 is on a distinguished road
ok thank you
is this the route i should go to lift it?
or is there something else i can do for somewhere around the same price?
im tryin to do 4 inches at least?
Old Mar 18, 2009 | 01:57 PM
4" with blocks is a bit much. You will end up with increased axle wrap when you get on the throttle which can lead to other issues.
You will not get too much cheaper and easier than a lift like this though.
When I lift my K5 more, it will be with a shackle flip in the rear and a 52" upgrade up front. But that is a bit more $$$ than a block set.
Old Mar 18, 2009 | 03:11 PM
bignate74's Avatar
how about like 3 with blocks?
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
2Tone
Mar 29, 2007 12:20 AM
alamantia
Suspension Tech
Nov 17, 2006 11:14 AM
tommyd
Suspension Tech
Aug 25, 2006 12:11 AM
4lowlife
Suspension Tech
Mar 8, 2006 03:53 PM
