Noisy injectors
Hi everyone,
Let me first say thank you to all who share their knowledge on this forum. I am a new member but have learned alot from reading posts before joining.
I recently bought an 88 with TBI and the injectors seem noisy. They have a bit of a buzz sound to them. I have had this blazer about 4 months and this just started. Are they going bad? And how common is that?
I searched for this and didn't see any posts, any help is appreciated.
Patrick
Patrick
Check the injector pod bolts. There should be three of them if I remember correctly. If they are loose, it can cause quite a racket.
Also check the location of the fuel lines. They sometimes can hit the firewall at the back of the engine.
It is also possible that you have a restricted return line which is causing excessive pressure to the injectors. A restriction could come from a twisted or bent line. This can sometimes occur right where the lines enter the back of the throttle body if someone isn't careful taking the lines off.
The Beep
Feb 10, 2009 09:08 AM
chevyman30571
Feb 26, 2008 06:32 PM
Raider Fish
Jan 17, 2008 02:38 PM
