replaced everything still having steering problem
Old Dec 10, 2012 | 11:28 AM
70-K5's Avatar
70-K5 is on a distinguished road
I'll mail you one for $25, just pulled it yesterday.
Or you can get one from any junkyard.
Old Dec 10, 2012 | 01:28 PM
cmccadams's Avatar
cmccadams is on a distinguished road
i'll take it, now how to I go about paying you? I have some bully adjustable step bars I took off of mine that i'm not using if you want to trade. Just thought I would throw that out there, I will never be using them. They look like these. Bully Adjustable Side Steps AS-500 - SummitRacing.com
Old Dec 11, 2012 | 09:52 PM
abig84's Avatar
The component you need to chance is the steering arm. You have a raised steering arm that is designed for 4-6" lifts. The drag link needs to be parallel to the ground. If you have an option you want it to slope up towards the pitman arm instead of how it is right now.
x2
a stock arm is good up to 2 inches of lift,
just a little heads up that arm is a mudderfudder to get off of there, dont just expect to unbolt the three bolts and its gonna come off. google around on different methods of getting it off. mine usually consists of burning the old one off, or putting it in a vise and hitting it with a sledge hammer, 2,384 times. you may get lucky if it was just put on but theres actually some goofy crush cone washers that go in there that cause you a bit of problems when trying to remove them
also the dropped transfercase and sway bar probably isnt needed for anything under 4 inches but ddont think it will hurt anything
Old Dec 12, 2012 | 10:16 AM
70-K5's Avatar
I've found the best way to get a steering arm off is to remove the caliper and beat from the back. If you leave the caliper on there just isn't a good way to get to the right spots.
To remove there are the three nuts that you can obviously see. What you can't see is what looks like washers are actually cones that do a very good job of seating the arm onto the knuckle. You need to vibrate those cones so that they back out, after that the arm just lifts off.
Oh, and you need a pickle fork to get the drag link end off... just beat and repeat.
Here's how I took off my last steering arm, I was a little cocky and had my wife take a video.
See if it works:
Dec 4, 2012 3:20pm | Facebook
Old Dec 14, 2012 | 09:45 AM
cmccadams's Avatar
Thanks guys, i'm going to try to get it done next weekend. I'll have to check out the video this afternoon, they have Facebook blocked up here at work.
Old Feb 3, 2013 | 08:39 PM
1948 Chevy's Avatar
1948 Chevy is on a distinguished road
Did you find a stock steering arm? Where did you get it. I need one also.
Can you tell me how flat it is compared to the 4" lift version?
Old Feb 4, 2013 | 10:03 AM
70-K5's Avatar
I mailed him one.
Where are you at?
Old Mar 27, 2013 | 06:50 PM
ma454mike's Avatar
ma454mike is on a distinguished road
Should be able to find a stock steering arm in any salvage yard.
jezzika39
Aug 21, 2012 01:15 AM
zahaeus2005
Aug 15, 2012 07:56 AM
butters
Nov 17, 2009 07:21 PM
MerCiLeSS
Jun 20, 2009 12:44 PM
xluke
Feb 1, 2009 10:33 PM
