Tailgate - Window Removal
Old Oct 11, 2022 | 12:38 PM
harryB's Avatar
harryB is on a distinguished road
Default Tailgate - Window Removal
re '75 K5, tailgate window crank LOCK failed when window was rolled down.
To REPLACE LOCK, window must be pulled out to access crank assembly to remove it.
Q > how to pull out the glass with the glass down (90% of the way down) and crank/lock not working ?
thanks
Old Oct 11, 2022 | 07:39 PM
If you can see the bottom of the window, you should see two sets of bolts that hold the tracks (called 'cam' in the factory illustration/parts manual) on the bottom of the window sash These 4 bolts can be removed to disconnect the window from the regulator which should then give you access to remove the regulator & from there the crank assembly.
The two pictures above are for the power rear window option, but the parts I am talking about are shown as items #15 (bolts), #65 (cam or track), and the window assembly would be #66-#68.
The illustration above shows what goes into the factory crank handle. I do not have the part number listing for this illustration handy though.
Old Oct 14, 2022 | 12:07 PM
harryB's Avatar
thanks.
(I assume you meant to say 'access to remove window' & from there crank ***.)
have crank/lock rebuild diagrams from prior research.
best,
hb
BobLoblaw
Dec 13, 2010 07:00 PM
84 Bucket of Bolts
Jun 7, 2010 04:02 PM
Imperator
Mar 31, 2010 04:32 PM
Spectreblazer
Feb 18, 2010 08:09 PM
84_K5
Jan 7, 2010 02:24 PM
