time for over haul
Old Oct 20, 2010 | 01:06 PM
k5blazer's Avatar
k5blazer is on a distinguished road
Would that tranny fit in a 700r4 mounts are would i have to do some fabrication?
Old Oct 20, 2010 | 01:08 PM
k5blazer's Avatar
I have been doing a little research and it says that they werent stock in a blazer so i guess that I'll be doing some fabricating
Old Oct 20, 2010 | 05:26 PM
The TH400 is longer than the 700R4/4L60/4L60E so you would have to move everything back and lengthen/shorten the front/rear driveshafts respectively. Also, the output shaft from a TH400 is larger and has a different spline count than the 700R4 so the input shaft on the transfer case would need to be changed and you would likely have to get a different adapter.
Old Oct 20, 2010 | 06:50 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
i got a 700r4 from monster transmission and it is holding up wonderfully the mid rated one witch is the one i got is rated for 500HP, i also got a 1800-2000 stall converter from them
http://racetransmissions.com/store/p...products_id/30
Old Oct 21, 2010 | 02:20 PM
k5blazer's Avatar
Thank you i will most like be getting one from them and do the go green swap.
MuTaLiZeD
Mar 21, 2011 11:23 PM
ComputerNerdBD
May 8, 2009 06:59 AM
BigBlue822
Apr 8, 2009 07:35 PM
stevelknievel
Nov 3, 2008 02:34 PM
nezz19
Jul 11, 2006 10:01 AM
