Is it all in my head?? I think I like the spacers..
Old Aug 12, 2018 | 12:35 PM
  #41
Originally Posted by swartlkk
Your CG will remain in the same relative location. The only way to lower your CG is to physically move the weight closer to the ground. Widening the stance does not move the weight by any appreciable amount (only the weight of the new spacers has been added). It will handle better because of of the change in the roll center location which will move closer to the CG.
"Roll-Center", That is what the concept is called! Thanks for the link. I'm saving it for later.
Old Aug 12, 2018 | 12:44 PM
  #42
Originally Posted by DonL
but those are some nice looking spacers... I want to get a pair of 4 and throw them on. And also keep my 1.5s in the back. But I need to get a pair of hub centric.
As for the hub-centric-ness of the spacers I used, at least for the rear axle, they fit perfectly on the axle hub and the wheel fit perfectly on the spacer hub, both with hardly any wiggle. I was very pleased with that.
I have it easy in that very little salt is ever used on our roads. (Salt use on our roads is actually new to us in northern Idaho.) As such there was only slight surface rust on the rotors with nothing to interfere with the fit. I used the nuts that came with the kit to mount the spacers as the regular GM lug nuts would have been too tall.
With the 1.25" spacers, the lug studs and bolts were just a tad recessed into the spacer (1/8"?) and I was able to get 8.5 turns of the nut for good engagement with the stud.
Old Aug 14, 2018 | 09:12 PM
  #43
don james's Avatar
don james is on a distinguished road
I had no idea that i was so keen on tire placement until i put the 1.5's on the back and the 1.25's on the front.........I rounded a parking row at wall mart [that I have done many times before] and rolled right over the curb with the rear and also I cut into a parking space on an end with a curb [on the driver side and misjudged that one too.......... but I still like the set-up :-)
Old Aug 14, 2018 | 10:06 PM
  #44
Radar696's Avatar
Radar696 is on a distinguished road
They do look pretty good but just remember, you are putting more stress on the rear axle bearings as you push the wheel & tire further out.
Although considering you are not running overly large tires; 30x9.5x15; you should be safe.
Just remember to check from time to time for excess wear.
Radar
Old Aug 14, 2018 | 11:46 PM
  #45
Radar
Yes, I did not want to go too extreme; e.g. no spacers on the front, limiting the spacers to 1.25", not an extreme amount of suspension lift.
Devin Banks
Jul 4, 2019 09:43 AM
wlorton
Tires and Wheels
Jan 21, 2010 08:17 PM
cameronp29
Tires and Wheels
Sep 25, 2009 06:54 AM
jdblazin
Tires and Wheels
Nov 19, 2007 06:39 PM
davtak
Sep 20, 2007 03:31 PM
