Bigger heads or new block completely?
Old May 25, 2012 | 08:52 PM
chunkster5979's Avatar
chunkster5979 is on a distinguished road
Default Bigger heads or new block completely?
I want a little more power out of my truck and i was wondering what would be the more reasonable choice. I could go for bigger heads and bore it out to get a boost in power.
Or should i just run this engine into the ground and find and 350 from like a camaro or rebuilt from somewhere and replace it with that.
Right now its got a 305 with the 700r4 transmission and only about 160HP.
Old May 26, 2012 | 08:05 PM
cleburne red's Avatar
The problem with a 305 is the bore is too small. And you can never bore it enough to hit that 4" bore a 350 has. Having said that, the same performance stuff that works on a 350 will work on a 305. Heads, cam, intake, will all boost the power of a 305. If you're looking for real power, though, the 305 will never cut it. The bore is simply not big enough to breath enough to make any power. 350's are so cheap they're practically growing on trees! That's the route I would take to get any horsepower.
Old May 28, 2012 | 06:37 PM
Thanks ill probably just do that then, hell I go the extra mile and do the whole powertrain, and just rebuild the tranny if its not in to bad a shape
96jimmyslt4x4
Jun 26, 2011 12:45 AM
MacArthur
Tires and Wheels
Jun 14, 2011 08:51 PM
lil_blazin
May 10, 2009 05:20 PM
WolfPack
Headers, Intake, & Exhaust
Apr 17, 2008 12:04 AM
bkabina
Feb 25, 2007 08:41 AM
