california intake
Old Apr 30, 2010 | 08:19 PM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Default california intake
received the air intake from walnut california for a total of $ 55 shipping included.
they say after i make the install to disconnect the negative for 5 minutes then hook up again . that should make the computer rethink itself and make any adjustments.
does that sound right to you ???????
i am wondering if it will show a code.....
Old Apr 30, 2010 | 11:58 PM
84BlazerS10's Avatar
that sounds right yeah, basically by disconnecting the battery you are clearing the ecm memory.
Old May 1, 2010 | 12:52 AM
jdespain's Avatar
Pics, please. Interested in seeing it!
Old May 1, 2010 | 01:50 AM
Brian_D's Avatar
yes pics
Old May 1, 2010 | 05:52 AM
there is one hole in the tubing with a plastic grommet thru it.
thanks for the input.
no pics yet.......................
took some pics of the california intake but the wife and i do not know how to project it on this website.........................................
Last edited by swartlkk; May 1, 2010 at 07:32 AM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 1, 2010 | 07:33 AM
Check out the 'Forum Help & Suggestions Center' section at the bottom of the main page and look for the 'Image Posting FAQ'.
Old May 1, 2010 | 02:02 PM
Default intake
hoooked up my $ 55 intake from walnut california and everything fit fine with no problems. took her out for a ride and she sucks air like a vacuum cleaners
looking under the hood at the drivers side by the firewall is a t fitting that looks like some window washer or that. the hose that goes from the t... to the edge of the drivers fenderwall and disappears. it has several breaks in it. how the heck do you follow this hose, and where does it go.
how do you replace it ????????
Old May 1, 2010 | 02:11 PM
rriddle3's Avatar
*This is the third thread you have started concerning your new intake. Please be advised that double posting is against Forum rules. I have combined the threads, so please keep all related questions and issues in one thread*
Old May 1, 2010 | 04:05 PM
A little bit of effort with a search will turn up a multitude of posts about this vacuum line. The line should go into the vacuum reservoir located inside the driver side fender.
As far as replacing the line... Just get some new vacuum line of the appropriate size (take a sample in to the store with you) and remove the old line and install the new.
Old May 1, 2010 | 05:50 PM
Default Rubber hoses
thanks for your quick response concerning the hoses.....
ericthughes
16
Feb 11, 2010 07:40 PM
76beast
Jul 8, 2009 12:06 AM
rxm6
Mar 31, 2009 07:29 AM
manfish*
Nov 6, 2008 05:31 AM
blazeofglory
Nov 5, 2007 08:31 AM
