Driving Lights?
Old Sep 11, 2008 | 03:02 PM
rocktheguitarist's Avatar
rocktheguitarist is an unknown quantity at this point
Default Driving Lights?
how can i wire a pair of driving lights, or where can i get it done. normally i do everything myself, but wiring has proved a bit tricky for me. if anyone can help, please do!
Old Sep 11, 2008 | 11:13 PM
Kage0113's Avatar
Kage0113 is an unknown quantity at this point
Default RE: Driving Lights?
Did you already purchase the lights? Some lights come pre-wired and when I had a set of those I just cut the main power wire and had it run through my DRL fuse. I hated the pre-wired ones. What kind are they? It might help if everyone knew. I'm not sure cause I don't know how different it is between brands. Another thing to know is do you want them to run through your high beams? This meaning that they only work when you turn on your high beams. There is a way to avoid this cause there was no way I was gonna do that considering my low beams a 10 times brighter than my highs. Give us more info and this will be an easier question to answer, IMO.
Old Sep 13, 2008 | 07:42 AM
drperry's Avatar
Any truck shop, dealership, or car audio place will install them for you... They'll charge you 2 hours labor for it, though.
If you bought the kit new, it's peanuts, as all you have to do is read the instructions
Usually, there's a red wire with a fuse in it... That goes to the battery.
Black gets grounded to the chassis.
If it's a little bit higher quality, it should've come with a relay, in which case you run a wire from the switch to the relay... Much better and less wires to run that way.
Old Sep 18, 2008 | 09:07 AM
GeorgesBlazah's Avatar
GeorgesBlazah is an unknown quantity at this point
The wiring for that came with my PIAAs was not only complete/easy, but made great too.
edavison
Dec 20, 2010 09:55 PM
minijosh
Sep 12, 2006 03:57 PM
Whittaker
Sep 10, 2006 05:38 PM
BlaZeR FXB1581
Apr 30, 2006 04:14 PM
Deadeye
Aug 13, 2005 08:40 PM
