Ground wire
Old Jun 26, 2023 | 09:33 AM
Brayden young's Avatar
Brayden young is on a distinguished road
Default Ground wire
What problems could a split open ground wire cause??
Old Jun 26, 2023 | 09:39 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
That's not a split open wire. That plastic sheathing is known as wire loom and it's all split down one side so you can get it over the wire(s).
Old Jun 26, 2023 | 09:45 AM
Ok would it still work the same because I have been haveing electrical problems in my 2002 Chevy blazer and every time I move or mess with that wire everything works again then stops working again
Old Jun 26, 2023 | 09:51 AM
I don't know what you're asking but if moving that around affects anything, inspect it for worn or torn wires and a bad connection at the ends.
Old Jun 26, 2023 | 09:55 AM
Ok thank you I will
Old Jun 26, 2023 | 11:16 AM
GeorgeLG's Avatar
If you dont find something at one of the connectors/ends as WH suggests, cut the zipties and move each loom on its own until you find the problem one and then carefully cut and electrical tape wrap at the slit and start to pull the wire bundle out to see the beak/short/corrosion).
George
dhud64
Feb 17, 2015 06:39 PM
boogie1077
Nov 7, 2013 03:01 PM
Keystoneguy91
Oct 30, 2012 08:44 AM
blazerowner65
Oct 10, 2011 03:09 PM
JerryB52
May 16, 2011 11:34 PM
