Handicap and need ideas/advice
Old Sep 27, 2012 | 02:49 PM
drcoconut's Avatar
drcoconut is on a distinguished road
I can walk for about 10 feet before my legs give out. In my old rig I would drive up onto the lift at the rear of my F150, pull myself off by holding onto the tailgate, flip the switch to lift the power chair up off the ground then "wall walk" down the side of the truck to get to the cab. "Wall Walking" is a technique handicap people use to steady themselves. We "walk" or steady ourselves by walking down the wall as we walk down the hall.
The prob with the blazer is she is not heavy enough to carry the big heavy power lift and chair. My solution is to not use a power lift but use an aluminum carrier with a folding ramp on one end. The purpose of bagging the rear is to be able to lower the rear from ride hieght to as low as I can to the ground. That way the angle of the ramp on the is not so steep and hard to get up. Also the lower to the ground the shorter the ramp can be. Optimally you want a 1" drop form every 12" of run in case you are in a manual chair or the battery gives out in your power one.
The ramp will plug into the cat III trailer hitch hole.
That thing with the passenger door opening wider sounds like a good idea but it wouldn't really work for me since I don't want the power scooter in the Blazer with me.
Old Sep 27, 2012 | 03:17 PM
neo71665's Avatar
If you are just wanting the frame to rest on the axle and that be the lowest you can do a bag over monoleaf in the rear. Even that will be pushing your budget.
If ya wanting the frame on the ground thats gonna be way out of your budget. Gonna have to notch the frame, rework the interior panels, tub the rear, 4 link, bags, and air system.
my firstgen before i put one ton suspension under it would handle 500 lbs. It would squat the rear but i've had that in bags of concrete in the back before. With air you can easily jack it back up tho.
Old Sep 28, 2012 | 02:09 PM
trobbins's Avatar
what style back doors you got hatch or the double door?
Old Sep 30, 2012 | 07:03 PM
trobbins's Avatar
you figure it out, still what style back end do you have
Old Oct 3, 2012 | 11:12 AM
drcoconut's Avatar
I don't know why prev post did not post but I'll try again.
I can walk about 10 feet before my legs give out.
If I have a lift on the back with a hinged ramp,
the lower I can get it to the ground,
the less steep the ramp incline will be and the shorter the ramp will have to be.
I will need to install at least some "load assist" air bags to stabilize the weight of the lift and scooter hanging off the back.
I thought stepping up to a larger bag might give me a lower drop.
Attached Thumbnails Handicap and need ideas/advice-hitch-mounted-carrier.jpg   Handicap and need ideas/advice-pursuit-xl-scooter.jpg
Old Oct 3, 2012 | 12:01 PM
trobbins's Avatar
what if you got a drop down hitch like you see on lifed trucks that are pullin a trailor those long hitches like that, dont know if work but you could look into that
Old Oct 3, 2012 | 12:38 PM
drcoconut's Avatar
trobbins;
most of the time the simplest ideas are the best.
I'll give it a shot. If it doesn't make it scrap the driveway curbs .......
let you know
thanks
Old Oct 3, 2012 | 06:32 PM
trobbins's Avatar
deff let me know, just thought of it cause i saw one of thos hitch on a truck that came into my work so let me know for sure
Old Oct 4, 2012 | 07:32 AM
trobbins's Avatar
didnt know if you know but with thos hitches they make two diff kinds a solid one an one that has holes cut out for a pin to go threw so you can raise an lower but if get solid one can always drill it out
nstlol
Oct 23, 2015 08:20 PM
chris015
Sep 30, 2012 12:16 PM
JasinP
Sep 10, 2011 09:47 AM
techboy89
Mar 22, 2011 08:35 PM
BlazerGuy2001
Lifting Tech
13
Feb 20, 2010 03:55 PM
