How to easily remove leaf spring shackle bolts.
Old Sep 19, 2017 | 12:22 AM
MountainDew's Avatar
MountainDew is on a distinguished road
Default How to easily remove leaf spring shackle bolts.
I have fought many leaf spring hanger bolts out from the biggest air hammers to just outright cutting them off with a torch or cut off wheel but just yesterday I figured out a new method and would like to share it. The ball joint press.
Check this out.
Old Sep 20, 2017 | 11:29 AM
abig84's Avatar
good advice, ive done that a few times but most the time you just end up pushing out the cut bolt and inner sleave. most the time i just cut the bolt, drop the springs down, burned out the bushings then air hammered the sleave out of there.
Old Sep 20, 2017 | 12:13 PM
Rusty Nuts's Avatar
MountainDew is on the mark. I used the Harbor Freight ball joint press to replace my shackle and spring bushings last month. I've recommended it in two shackle question threads since then. $80 was worth it.
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
bigdaddykane93
Lifting Tech
Jun 21, 2010 11:34 AM
tony991
Apr 21, 2010 05:52 PM
rebelchevy
Lifting Tech
Sep 19, 2009 04:06 PM
g4mbl3
Jan 1, 2009 07:52 PM
