Jimmy 4dr standard tranny swap
Old Aug 25, 2019 | 08:32 PM
  #31
No problem. Hopefully that will give you what you need.
Old Oct 5, 2019 | 06:10 PM
  #32
SRIslash's Avatar
SRIslash is on a distinguished road
Well it is up and running. I still have to sort the backup switch out on the side of the tranny. But I’m going to get it into MY YARD to sort the small stuff out.
A little heads up, GM does not want to(or can’t) flash the PCM for the auto. I do have the PCM from the manual truck but it would start but not run. So I found out that there is security built into it and there is a ‘relearn’ procedure to perform.
i did this and all is good now. Relearn procedure is easily found on the net.
Old Oct 28, 2019 | 06:16 PM
  #33
SRIslash's Avatar
Well there is the interior. It had a console so instead of messing with the key release wires down at the old console I rigged a button release with a tube JB Welded to the backup key release within the steering column.
Just the backup lights for completion but I found the diagrams under ‘Lighting’.
Old Oct 28, 2019 | 10:50 PM
  #34
Hess13x's Avatar
Looks good. I would like to have a standard in my jimmy.
Old Oct 29, 2019 | 06:24 AM
  #35
Looks good! I miss my s10 zr2 for the manual shift... I shouldve kept that truck
Old Oct 29, 2019 | 07:50 AM
  #36
Looks like it came from the factory like that.
Old Nov 17, 2019 | 09:28 PM
  #37
SRIslash's Avatar
Thank you Tom. I haven’t checked in in a bit as I have been struggling to find that annoying occasional misfire. A few experimental sensors later and ended up with a new distributor. All fixed now. Jimmy is going great, new stereo head unit, key fobs for alarm/locks. Next take care of that drivers seat before moving to bigger things. Thanks guys for all the help so far.
Great to be wrenching again, Shawn
Invictus
Mar 4, 2010 08:27 PM
K5joker
Oct 18, 2009 06:55 PM
wetdog
Dec 13, 2008 09:30 AM
Blahman20
Jun 14, 2007 11:14 PM
Bosaliniee
Engine & Internal
Feb 1, 2007 10:12 AM
