Need help with misfire 2001 Chevy Blazer LT
Old Mar 20, 2022 | 06:49 PM
Madouglas's Avatar
Madouglas is on a distinguished road
Default Need help with misfire 2001 Chevy Blazer LT
I have I have a 2001 Chevrolet Blazer LT 4.3L. I replaced all spark plugs, wires, cap, and rotor but still have a code of a misfire in cylinder 1 but my cylinder 1 spark plug goes to Cylinder 3 on the distributor cap and cylinder 3 spark plug goes to cylinder 1 on the distributor cap. It's the only way it will run, if I reverse them the check engine light flashes and the vehicle starts to shake what do I do?
Old Mar 22, 2022 | 11:31 PM
GeorgeLG's Avatar
Here you go:
George
Old Mar 31, 2023 | 07:32 AM
KeithSalmons's Avatar
KeithSalmons is on a distinguished road
I am also facing the same issue.
Old Mar 31, 2023 | 09:14 AM
GeorgeLG's Avatar
  1. Make absolutely certain that your wire routing is correct
  2. Measure the resistance of each wire and inspect for cracks
  3. Inspect under the distr cap for carbon traces or defects
  4. Get CMP retard within spec with a capable scanner
  5. Mist the engine running in the dark and look for arcing
  6. Be certain that the distr cap, rotor, wires and plugs are all AC Delco and the correct part numbers
George
Madouglas
Oct 14, 2022 11:30 PM
n6601gc150
Dec 3, 2019 07:55 PM
DreadpirateJosh
Aug 10, 2016 10:24 AM
todd89
May 13, 2013 06:46 PM
iwaymer
Nov 21, 2011 08:26 AM
