Open The hood
Old Apr 18, 2014 | 09:54 AM
user_13120's Avatar
user_13120 is on a distinguished road
Originally Posted by cubawashere
yeah and you may break the grill by flexing over there....
Did you try again with a buddy? Use vise-grips rather than pliers and lock them on for a better grip. I guarantee, you'll have no trouble. I've done it too many times
tried it, the wire is broken somewhere along the line.... so it wouldnt work
Old Apr 18, 2014 | 03:03 PM
cubawashere's Avatar
cubawashere is on a distinguished road
Then you will have to resort to what Rich above said in post #7....as quoted from the thread he posted:
"If the cable is broken, you reach in behind the grille with a small hooked tool and find the cable going to the latch, hook the cable and pull it out 'this will take quite a bit of force' so you can grab it, you then remove the plastic housing and grab the steel cable with a pliers or other tool and from the latch side- pull hard to release the latch. you should then will have to replace the cable later. Also lube the latch."
Old Apr 18, 2014 | 03:22 PM
newguy's Avatar
Between the grill and the hood, you may have to bend the grill plastic some. you`ll see 2 bolts. Use a socket and an extension and remove the 2 bolts. your hood will open
chris015
Feb 14, 2012 10:20 AM
sprbld417
Apr 25, 2011 07:28 PM
Hanr3
Sep 11, 2006 02:10 PM
bat119
Jun 15, 2006 06:37 PM
bat119
Jun 13, 2006 11:15 AM
