Passenger floor wet
Old Oct 22, 2009 | 07:07 AM
Agree on the windshield seal and/or door seal. If it is wet up under the dash, it likely is the windshield.
Besides water being bad for the modules under the dash, it can also damage the grounds.
Old Oct 22, 2009 | 08:24 AM
Flying3's Avatar
Flying3 is on a distinguished road
Interesting that this thread was brought back today. I have ignored the wet passenger carpet which was probably a mistake because my 4WD no longer engages. I tested it a couple of days ago, and heard an awful grinding sound in the front end. Now I get both 4hi and 4 lo lights flashing when pressing either button while in neutral and nothing when trying to engage 4hi while in drive.
Just this morning I brought it in for someone to look at. I'm hoping for the best and expecting the worse.
Old Oct 22, 2009 | 08:39 AM
The grinding sound is most likely due to either an actuator/cable/vacuum line problem or a problem with the vacuum switch on the transfer case (if you have the NV233 - 3-button switch on the dash).
The flashing light issue could be a corroded TCCM connection or a bad ground under the dash. Always pays to start there on these. It could be a cheap easy fix.
Old Oct 22, 2009 | 08:13 PM
Shmuckles's Avatar
Shmuckles is on a distinguished road
Whoops, wasn't sure about how to go about posting as I am new to the forum world. But I now understanding that "birthing" a new post is much more effective than the resurrection of an old one
Thank you for your guys' advice and I checked into your suggestions.
Still however, it remains a mystery it seems.
It is really bizarre... I ran a hose over the hood, windshield, doors etc and I couldn't get it to leak?? I am positive (but now wondering if I'm loosing it) that the doors were fully shut and windows closed when the rain hit...
But I am still having problems with the headlights not coming on and not sure if water damage has hurt a ground etc. Luckily they do come on when I hit the dash, which leads me to think that it is a loose connection/bad ground of sorts? I have heard electrical problems can be a nightmare to diagnose, should I even attempt, or just cut the losses and take her in?
As for the leak issue...It is supposed to rain here again tonight, so I made damn sure everything was shut up tight and now I play the waiting game to see if I have any surprises tomorrow.
Thanks again for your input!
Old Oct 23, 2009 | 01:36 AM
foxxie's Avatar
Don't know if this will help but this is what happen to Kiwi blazer with wet floor issue https://blazerforum.com/forum/general-chat-34/my-poor-truck-31258/
yuri39
Apr 4, 2014 01:42 PM
ely0569
Apr 15, 2012 05:33 PM
littleblueblazer
Apr 25, 2010 02:43 PM
emf_1978
Aug 9, 2009 06:05 PM
bigbill23
May 29, 2007 01:25 AM
