straight axle
Old Mar 14, 2011 | 06:36 PM
jeff2006's Avatar
jeff2006 is on a distinguished road
Default straight axle
does anyone know what strait axel will fit right in on a 91 blazer i know i need to do the leaf springs but what axel will bolt up to the drive shaft
Old Mar 14, 2011 | 08:18 PM
Logan's Avatar
Logan is on a distinguished road
use a cherokee drive shaft, and any drivers drop solid axle will fit. Cherokee d30 and wagoneer d44 work best I believe.
Old Mar 14, 2011 | 08:29 PM
Benedict1337's Avatar
yea those are the most popular axles, if anything breaks on those there are a million places that carry replacement parts.
Old Mar 15, 2011 | 09:18 AM
jeff2006's Avatar
i was reading that somewhere than i was looking an found a 95 cherokee but it has coils up front are they all like that or just newer ones or do i just replace the pirches for leaves
Old Mar 15, 2011 | 06:40 PM
WolfPack's Avatar
Probably will be easier to find an older Wrangler axle with leaf springs than trying to modify the Cherokee one.
Also look for Wagoneers...most came with D44s and almost all came with leaves.
Old Mar 15, 2011 | 07:21 PM
oktain's Avatar
* Moved to General Chat*
The Build section is specifically for cataloguing builds.
Old Mar 15, 2011 | 11:30 PM
You can do a co spring set up with control arms and such. That will give you a better ride quality but also involves more work. If you want solid axles for the purpse of off roading id stick with the leafs thats the simplest setup not too many things can break. If you are looking to replace your front end parts because of junky settup you may want to look into doing the coil spring setup, you can do it both for the front and rear. If u check the s10 forum someone did that with his 2nd gen 2 door i believe hes running 37's but ypu dont have to go that big
muddog89
Feb 16, 2013 10:17 AM
s10 blazer dude
Lifting Tech
15
Sep 3, 2009 03:10 PM
02 Vortech
Nitrous, Super Chargers, & Turbos
Jul 23, 2009 08:13 PM
984x4blazer
Suspension Tech
Jan 29, 2007 12:09 AM
SniperX13
Headers, Intake, & Exhaust
Jun 26, 2006 01:55 AM
