straight axle
You can do a co spring set up with control arms and such. That will give you a better ride quality but also involves more work. If you want solid axles for the purpse of off roading id stick with the leafs thats the simplest setup not too many things can break. If you are looking to replace your front end parts because of junky settup you may want to look into doing the coil spring setup, you can do it both for the front and rear. If u check the s10 forum someone did that with his 2nd gen 2 door i believe hes running 37's but ypu dont have to go that big
02 Vortech
Nitrous, Super Chargers, & Turbos
Jul 23, 2009 08:13 PM
