switching oil brands??
Old Jul 12, 2008 | 12:13 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
Default switching oil brands??
i currently use Q horsepower full synthetic and i would like to switch to mobil 1 synthetic now i know certain types of oil dont mix well, causing sludge build up etc., but does anyone know if i will run into any problems going from the q to mobil 1?
Old Jul 12, 2008 | 12:28 PM
Default RE: switching oil brands??
I wouldn't worry one bit about it. Shouldn't have any issues.
Old Jul 12, 2008 | 12:31 PM
mikeinwi's Avatar
alright thanks..lol time to run the checker now
Old Jul 13, 2008 | 11:40 PM
Kage0113's Avatar
Kage0113 is an unknown quantity at this point
I wouldn't worry about it. you would get sludge going from conventional to synthetic but going from synthetic to synthetic you should be fine.
Old Jul 14, 2008 | 10:22 PM
Good_Chevy's Avatar
Good_Chevy is an unknown quantity at this point
I also heard that if you switch to synthetic oil you can't go back to conventional oil because it'll screw up your gaskets from expansion and contraption, and you'll end up with a leek.
Old Jul 15, 2008 | 01:35 AM
curse's Avatar
curse is an unknown quantity at this point
So what if you dont know what was in it before? Is there a way to completely drain the previous oil?
Old Jul 15, 2008 | 06:48 AM
That is another myth from the very beginning of synthetics. With the way oils are now, you can switch back and forth with no worries. I did it with my Bravada when I had a oil pan gasket leak. The leak was due to loosening bolts. The synthetic oil showed it to me and I switched back to dino juice so I wasn't wasting expensive oil. Fixed the leak and it was all good again. Switched back to synthetic and never looked back.
Old Jul 15, 2008 | 07:34 PM
95Blzr's Avatar
95Blzr is an unknown quantity at this point
When I bought my car im assuming the owner before me used regular oilbecause of thecheapo fram filter. All my cars I get I switch to Mobil 1 Synthetic and a Mobil 1 or K&N Filter. Never Had a problem.
Old Jul 15, 2008 | 08:29 PM
mikeinwi's Avatar
thats exactly what im runnin now the mobil 1 with a k&n oil filter
Mark_D
34
Dec 5, 2011 08:02 PM
Project_95_Blazer
Performance & Brainstorming
15
Jan 20, 2011 04:12 PM
Big O
Jan 28, 2010 11:38 PM
samurai_24
Oct 2, 2009 12:39 PM
WhiteTie BlackJacket
Dec 14, 2007 04:53 PM
