Tire rack tailgate vs non tire rack tailgate
Hi, I'm new to this forum and haven't seen anything about this post..I appologize in advance if this has already been addressed..
I have a 2000 Blazer ZR2 with the rear tire rack that was in an accident. The rack was pushed into the tailgate and damaged it. Does anyone know if a non- tire rack tailgate will work with a tire rack tailgate...Can the brackets be transferred over or do I need to get a tailgate with the rack on it?
Thanks
Thanks
well u can do either they are probly plenty of them in your local pull a part yard i would go for a tire one if u can find one that way all you have to do is take the old one off and put on the new one on no drilling needed but if u cant find one all you have to do is measure the old one and drill new holes and put the parts on
Thanks everyone for your responses. Looks like a project for this weekend..I'm assuming that a non-rack tailgate besides being drilled out will also need some kind of reinforcement backing from the original tailgate.
HI Everyone. Just an update..the tailgate with the tire-rack is reinforced from the factory with a bracket with integral nuts...the bracket is spotwelded into place. I tried tearing out the old bracket to install on the non tire-rack tailgate I found at the pull yard but it proved to be too cumbersome (several hours). I was able to rip it out of the old tailgate, but there was no way to install it into the non tire-rack tail gate. I ended up driving about 50 miles to another pull place and found a tire rack tailgate from another ZR2 and installed that one in less than 30 minutes...it is just the wrong color so it needs to be painted...
