v8 in 95 blazer 4x4xgood or bad idea
Old Oct 13, 2011 | 05:29 PM
offroader8488's Avatar
offroader8488 is on a distinguished road
Default v8 in 95 blazer 4x4xgood or bad idea
what do you guys think about put a 350 in a 95 zr2
Old Oct 13, 2011 | 09:36 PM
Smitty Smithsonite's Avatar
Sounds like fun!
If I didn't have the '00 Jimmy sitting on blocks here in the driveway, I'd have gone the 350 route myself. Parts are cheap & widely available, plus you get a massive increase in torque - even with no modification at all. It's a win-win.
I think it'll cost a bit more than a V6 swap with the kit you'll need though, & I'm sure there will be alot of time consuming fabrication going on with little odds & ends - happens with any motor swap though.
Old Oct 14, 2011 | 11:47 AM
i have looked in to it and besides buying a motor and a motor mount kit and a oil pan extension kit i have everything i need. i had a 98 s-10 truck with the 4.3 that i put some mad patrs on and it was like having a 350 and i want the same thing out of the 95 and everyone said go v8
Old Oct 14, 2011 | 05:26 PM
NVANZEE's Avatar
go for it. Im in the middle of rebuilding a 350 to put in mine this winter. Just so you know you will also need electric fans and add/change a few wires around in the pcm connectors. Other than that its a pretty straight forward swap.
Old Oct 15, 2011 | 08:25 AM
i was told if you take a 350 and wire harness and pum out of a 95 chevy truck you can put it in to yous and just plug it all in but your rig has to be a 4.3 for this to work
Old Oct 16, 2011 | 11:12 PM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
It depends on what V8 you put in there. If it's a stock TBI 350 from a late 80s mid 90s truck, it only makes 210 HP. A Fbody 350 from the same years made 245ish HP with TPI. The 305s were worse. A TBI 305 made like 170 HP. The 4.3 CPI was the best performing 4.3 V6 (besides the turbo motors) since it makes about 190-200HP when it's running as it should.
I was seriously going to do the swap, until I totaled up how much everything would cost. It wasn't worth it, in my circumstance, to do it all without cutting corners. I paid $1000 for my '94 S15 Jimmy, and while it's in excellent shape, keeping a good running 200 HP 4.3 was the better route. Other circumstances may be different.
88s10Blazer
Dec 29, 2009 12:52 AM
Csmoney28
Performance & Brainstorming
May 9, 2008 06:06 PM
davtak
Sep 20, 2007 03:31 PM
davtak
Oct 2, 2006 11:07 PM
mojoman13
Engine & Internal
Sep 21, 2006 10:51 PM
