Worth repairing our Blazer???
Old Mar 27, 2011 | 01:03 PM
  #21
Benedict1337's Avatar
by any chance was it lowered at any point? I don't see why someone would go through all the trouble to weld that like that, because the front differential and axle supposed to be held on by just a few bolts to brackets
Old Mar 27, 2011 | 01:25 PM
  #22
dimone545's Avatar
dimone545 is an unknown quantity at this point
I cant see why the hell someone would weld that????????? The diff has like 2 bolts on each end for where it mounts to the frame and then I think like 1 or 2 more that go through the ears on the diff.
Honestly bro it sounds like your truck is more of just a daily driver, do you even use your 4x4? If I was in your shoes i would just pull the diff out and the front driveline and roll it as a 2wd truck. It will save you an *** load of money. The 4x4 is not something that is "needed" for the truck to function correctly its just an addition that comes in handy. Get what Im saying?
Old Mar 27, 2011 | 01:30 PM
  #23
yea I agree if you don't go offroad or drive in the snow I would just say screw the 4wd and pull the whole front diff out
Old Mar 27, 2011 | 02:36 PM
  #24
Poh's Avatar
Poh
From: Berrien Springs, People's republic of Michiganistan, Socialist states of American
Poh is on a distinguished road
yeah ..... I am betting he is near Duluth MN because he said something about going over the bumps in Duluth MN.
ditch the sway bar
SAS (straight axle swap) with a high pinion D30 from a Jeep and coilovers.
and half a day with some buddies to fix the coolant leak.
Old Mar 29, 2011 | 07:28 PM
  #25
m3ch's Avatar
m3ch is on a distinguished road
duluth huh.......thought i was the only one this far north in mn =P
Old Apr 1, 2011 | 03:56 PM
  #26
4good's Avatar
4good is on a distinguished road
there is no possible way the front dif bolt r rubbing the bell housing do you mean transfer-case and why would they have to make a new bracket you should be ale to find one at a junk yard or ask around the forum hell i probably have one but I'm not sure what your looking for . it sound like you need a second opinion good luck.
richphotos
Jan 12, 2012 05:57 PM
pnice74
Jul 3, 2009 12:56 PM
phillymick
Nov 9, 2008 07:54 PM
4x4blazerguy
Apr 7, 2008 12:24 AM
