General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Hard Start
Old Sep 20, 2006 | 04:06 AM
Gonzo7's Avatar
Gonzo7 is an unknown quantity at this point
Default Hard Start
While this may be a simple problem to fix I just wanted to make sure I wasn't crazy. I drive a 95 Jimmy s-15, w/ the 4.3l. vortec, 4wd, and automatic transmission, and as the tepurature drops I have been experiencing problems with starting. It could simply be an issue with the distributor, but I do know the battery is only three months old. What basically occurrs is when I turn the key I either get no response or a very dying, crank until the fuel gets a good spark. As soon as it starts I have no problems, acceleration is good, and idle is smooth. Thanks for your time and sorry for making you read my novel.
Old Sep 20, 2006 | 12:52 PM
Chevy Lover's Avatar
Default RE: Hard Start
Welcome to the forum.
If your battery is good and the Starter is cranking slow, you should check for starter draw. It could be a worn starter drawing too much power.Hook up a volt meter to your battery and see what the voltage drops to when you crank it over. The battery shouldn't drop below 9.6 volts.
Old Sep 23, 2006 | 10:47 PM
Gonzo7's Avatar
Thanks Chevy Lover, I'll give that a try, if I can get my hands on a volt meter.
Kevin Gore
Dec 13, 2013 09:35 PM
dubaholic2
May 24, 2011 12:44 PM
ejxjohnson
Sep 10, 2010 08:21 PM
Purple95Blazer
Aug 4, 2006 12:06 AM
vmx120
Dec 2, 2005 12:19 PM
