General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Hesitation
Old Oct 26, 2006 | 12:52 AM
Nemo's Avatar
Nemo is an unknown quantity at this point
Default Hesitation
I have a 2000 Blazer 2dr. 4X4 5-speed with 75,000 miles on it. When I am at a comstant RPM while driving every once in a whil I will get a moderate hesitation. I have also noticed it during steady acceleration too. Replaced MAP sensor, fuel filter, cap & rotor, plugs, wires, cleaned throttle body. I noticed it about a month or two after I installed a K&N cold air intake on it. Looking for any help I can get
Old Oct 26, 2006 | 03:22 AM
20Blazer00's Avatar
Default RE: Hesitation
Clean your MAF, if the K&N had excess oil then the MAF will get coated with not only the air cleaner oil but dust and dirt to....primary cause of these symptoms.
Old Oct 26, 2006 | 04:03 AM
Chevy Lover's Avatar
you might want to check that the EGR valve is clean also.
Old Oct 26, 2006 | 11:24 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
Could be a EGR valve sticking as stated by Chevy Lover. Remove it and give it a good cleaning. You may want to try some SeaFoam too.
Old Oct 27, 2006 | 01:40 AM
Hanr3's Avatar
Replace your fuel filter.
thebaf
Engine & Internal
May 18, 2006 01:08 AM
blazergirl15
May 15, 2006 12:13 AM
black19
Engine & Internal
Feb 22, 2006 12:13 AM
wahhen
Jun 10, 2005 10:56 PM
jp5162
Mar 1, 2005 10:11 PM
