General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Knob under driver's seat
Old 10-04-2006, 10:15 PM
Default RE: **** under driver's seat
If it does go to the front diff, most likely someone put in a manual disconnect for the front diff instead of running with the vacuum diaphram actuator to lock it in...
Old 10-05-2006, 12:44 AM
USMaverick101's Avatar
USMaverick101 is an unknown quantity at this point
hey im sorry it goes to the REAR differential
Old 10-05-2006, 01:58 AM
ORIGINAL: USMaverick101
Well I am just guessing but it might be some type of manual locking mechanism for the rear axle....Duh
The only way to find out is to either try it out or take it to a tranny/rear end shop to see if they can explain it to you.
Old 10-05-2006, 12:25 PM
what would locking it do? why and when do i need to do this?
Old 10-07-2006, 01:41 AM
tycobb280's Avatar
tycobb280 is an unknown quantity at this point
locking the diff. just means that youre locking the gears inside together so both of the tires will spin in a low traction situation instead of just one tire spinning like with an open diff. if its engaged and youre on dry pavement and you hear the tires chirping when you turn, its a locker. if the tires dont chirp then more than likely its not a locker, or its not engaging properly.
njk53
05-20-2011 05:16 AM
kickme005
09-06-2010 06:03 PM
classklown90
05-18-2009 11:45 AM
oktain
10-21-2008 02:45 PM
drperry
04-13-2007 08:51 PM
Quick Reply: Knob under driver's seat
