General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
raising torsion bar
Old Nov 11, 2006 | 02:36 PM
97blz4x4's Avatar
97blz4x4 is an unknown quantity at this point
Default raising torsion bar
hey yall i that that 4wd fixed after all,it was the transfer case switch and some old vacuum lines,but now i am im working on getting the tires to stop rubbing.i put new front shocks on it,but it still rubs when i hit a good size bump.how do i go about raising the torsion bars??
97blz4x4
brandon
Old Nov 12, 2006 | 10:22 AM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: raising torsion bar
towards the back of the bar is an adjusting nut/bolt. first thing is count the amount of thread each have showing, mark down or remember how many on each side. then measure the vehicles ride hieght on each side, from equal points on the frame to the ground. if one side sits higher or lower then adjust the screw accordingly until its level. you may have do this a few times to get it right. its also important to rock the truck back and forth and bounce the front end to really settle the suspension and get a true reading. now if you need to raise your height and the truck is level, you can simplify this method by turning each nut the same amount of threads double checking ground clearance in between each set of turns.
Old Nov 12, 2006 | 02:21 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
how far can you crank them before stuff starts messin up
Old Nov 12, 2006 | 02:25 PM
rooster's Avatar
only crank alittle at atime, and then cross check ur height. the less u gotta change the better, alot of time being in the undercarriage causes these nuts/threads to rust up. so hit them up with some wd-40 before you proceed, the last thing you want is to snap them threads.
gtmccormick
Apr 24, 2015 07:29 AM
Brocktward
Aug 16, 2009 12:35 AM
RWRIGHT
Feb 25, 2009 06:17 PM
Smoked
Tires and Wheels
May 7, 2008 10:40 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
