General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Sounds like Water Running when I hit the gas!
Old Oct 6, 2006 | 11:54 PM
Dodge Guy's Avatar
Dodge Guy is an unknown quantity at this point
Default RE: Sounds like Water Running when I hit the gas!
ORIGINAL: huskers95
Could just be an air bubble in the system. Dodge trucks do this all the time. The Fix is to run it up on some ramps and let it run for a while with the radiator cap off and that should purge the air.
Thanks for the help guys. I tried this last night and it seems to have done the trick.
Glad you got it fixed.
Old Oct 7, 2006 | 01:39 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
I too have a 2001 blazer that makes this same noise. However, my passenger side floor board underneath the rubber floor mat stays soaking wet. . . is this related? the fluid does not smell like coolant, it just seems to be water. . .
Old Oct 7, 2006 | 02:39 AM
Dodge Guy's Avatar
Check the drains on your AC condenser. They tend to plug up with all kinds of crap and the AC condensation has nowhere to go. Not sure where they are on Blazer as I've only had a blazer for a few weeks, But I know someone on here knows.
metalhead
Apr 25, 2007 09:26 PM
napalm dan
Apr 17, 2007 12:53 AM
bklahl
Jan 20, 2007 11:39 PM
cmsweet123
Dec 15, 2006 09:51 AM
camohog1
Jan 24, 2006 07:46 PM
