General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
squeek
Old Feb 22, 2006 | 06:36 PM
haloboy99's Avatar
haloboy99 is an unknown quantity at this point
Default squeek
this may sound a bit weird but can someone give me some ideas what would be making a squeeking noise in my blazer sounds like two peices of styrofoam rubbing together when i drive over anything rough even when its parked and i push the vehicle up and down it makes it to any ideas???? thanks
Old Feb 22, 2006 | 09:00 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: squeek
Could it be your back hatch? Mine squeaks. Is your spare tire mounted inside? Mine is, and THAT also squeaks.
Old Feb 23, 2006 | 03:34 AM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
Default RE: squeek
Mine does that, too, though I can only hear it with the window down, unless I push on the rear bumper..... I thought it was the leaf springs or their bushings. Then two shops checked it out and said it was one of the rear shocks. This didn't sound likely to me, but the second shop disconnected the shock temporarily and the noise went away. This shock only has about 4.000 miles on it. They said it was OK, working properly, just a little noisy, and I could either replace it or drive it that way. They put some chassis grease on the shock bushings, which may have helped some, but I won't really know until I start driving with the window open again or remember to try pushing on the bumper.
My back hatch squeaks, too, like Moonwater's, but that is a lot louder and more constant, and I consider it a separate problem. I've tried lubricating the weatherstripping with silicone spray and it hasn't worked. I can see a couple places where the rubber is worn down, in the two upper corners, and I'm going to try building up those spots with thick silicone from a tube, once the weather gets drier and warmer.
Anne
'91 S-10 Blazer 4WD 4.3L 2 dr
Old Feb 23, 2006 | 09:03 AM
tomsblazer's Avatar
tomsblazer is an unknown quantity at this point
Default RE: squeek
I had a loud squeeeeeek coming from the back area. It turned out to be a vent tube trapped between the break line and the frame in the passenger side rear wheel well. It was more of a metalic sound of course.
tammikm
Jul 15, 2009 05:26 AM
Jharper
Aug 21, 2008 09:36 PM
bill4848
Mar 8, 2008 10:13 AM
redpeppers
Jul 25, 2007 01:46 PM
mkatts
Sep 6, 2004 10:54 PM
