Vacuum line?
I am still having trouble with my 4wd. I found a rubber line 7/32 that comes out above the brake booster on my 95 blazer. The other end is attached to the black plastic ball that is mounted to the underside of my hood. The problem is I don't know where this is suppose to attach to. It heads toward the back of the engine. Can anyone help me with this? thanx. wnk.
It probably heads towards a plastic vacuum tee on the passenger side of the transfer case.
There is a vacuum switch on the upper right side of the transfer case that is fed by that vacuum hose....I believe.
kakn
Jul 22, 2007 09:14 AM
