Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Dual exhaust conversion
Old Aug 5, 2010 | 11:59 PM
kickme005's Avatar
Banned
kickme005 is on a distinguished road
Default Dual exhaust conversion
95 Blazer 4door i want to install a dual exhaust. What the best way to go? heard u lose back pressure. Do i just get a dual muffler that goes in and out 2 or make it dual starting from the engine(is that pssible)? what bout adding a crossover?
Old Aug 6, 2010 | 06:53 AM
Phil's Avatar
Search box is located at the top of this forum. Between the "New Posts" and "Quick Links" tabs. Every question can be found from using the search feature. Not trying to be a jerk or anything, but this question seems to get asked weekly. If you go to page two or three in this section I believe someone asked all of these questions in one thread not too long ago.
Edit: I get the feeling you're new to cars since you asked is it possible to start with duals from the engine. Dual exhaust means from your exhaust manifolds or headers (if you plan to upgrade to those), you run piping from the primary flanges of your manifolds/headers into either a Y-Pipe (single exhaust as already found on most cars from the factory), H-Pipe (For duals), or an X-Pipe (also used for duals). X-Pipe is the one most people opt to use, myself included on other applications. Duals on a Blazer are worthless. Again, not trying to be a jerk here, but this can all be found by searching.
Old Aug 6, 2010 | 10:39 AM
oktain's Avatar
Don't waste your time with "True duals" (Duals from the engine-back)... get a dual outlet, single inlet muffler and just run dual tailpipes from the muffler.
Also there are SOOO many exhaust threads on this forum, you just gotta look
Old Aug 6, 2010 | 05:32 PM
84BlazerS10's Avatar
I've always been told that just running dual exhaust just makes it look/sound cool where as true duals actually would provide a horsepower benefit.
Old Aug 6, 2010 | 09:55 PM
rriddle3's Avatar
Totally dependent on the engine set-up, but these engines don't fit the criteria without major internal and external mods.
Old Aug 14, 2010 | 11:42 PM
matt92's Avatar
matt92 is on a distinguished road
The exhaust setup on my car sounds GREAT!!!! I simply put on a flowmaster super 44, and had my cat removed. All that leaves is the pre-cat, and the flowmaster. It has such a great tone, and isnt too loud. But it's just the right volume.
Old Aug 15, 2010 | 08:05 AM
So, are you saying that certain cars could benefit from just duals and not true duals?
Old Aug 24, 2010 | 01:19 PM
88Vic's Avatar
88Vic is on a distinguished road
All depends on the piping size, the 4.3 would do well with 2" duals with free flowing mufflers, especially for low end torque. I'd say no larger than 2.25" pipes, that's the medium size for small block and LS trucks. I'd say go with a dual outlet muffler if you want duals and use 2.25" tails and run dual turndowns at the bumper, barely sticking out if you want to see them. I'd get the tips painted so they don't rust and look bad, i've seen white turndows on a white S10 and it looked really nice.
bobbyb64
Performance & Brainstorming
Oct 22, 2011 03:26 PM
S10SUV
Dec 29, 2010 12:28 AM
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
the_mind
26
Nov 26, 2008 12:45 AM
downhilryder
Oct 27, 2005 02:21 AM
