Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Rattle in my cataylic converter
Old Aug 30, 2011 | 04:26 AM
blazer2554's Avatar
blazer2554 is on a distinguished road
i was wondering since the emission controls in my country is not strict,is it possible to remove the cat completely or would it cause the engine light to come on and or can i cut it open to remove the stuff thats causing the rattling noise & reweld it again.thanx
Old Aug 30, 2011 | 06:51 AM
It likely will result in a check engine light without reprogramming the PCM to remove those codes. Of course that depends on what you are driving...
Old Aug 31, 2011 | 08:28 AM
appliancguy's Avatar
appliancguy is on a distinguished road
You can also get a spark plug anti fouler and drill it out (1/2 inch bit) screw o2 sensor on it and screw it into exhaust pipe. Takes the sensor out of direct exhaust flow...Off road only of course
Old Sep 1, 2011 | 08:10 AM
blazer2554's Avatar
can you please update me on what a spark plug anti fouler is or maybe a pic.thanx much appreciated.
just did a google on that anti fouler,nice idea-gonna try it out this weekend.
Last edited by swartlkk; Sep 1, 2011 at 08:46 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 2, 2011 | 09:26 AM
Default ok
Get a pack of them in the help section of your auto parts store....the 2 inch long ones. Use a 1/2 inch drill bit and drill out the center, this makes room for the o2 sensor. Try one first....you may need to stack them or use 2 of them. No more 420 code......off road use only
Old Sep 8, 2011 | 06:53 AM
litterbug's Avatar
when my cat started rattling i just bought a new one from summit. 75 bucks for a magnaflow and another 100 to install it. pretty cheap if you ask me. i probably should have gone the other route and just put a straight pipe in there with the anti foulers but i have to pass emmissions over here and sometimes they stick a hose over your exhaust to measure that crap.
Old Sep 10, 2011 | 02:48 AM
SpadedJimmy's Avatar
SpadedJimmy is on a distinguished road
My cat was 110 installed on my 97 gmc jimmy 4.3.....you guys need to shop aroundo
Old Feb 10, 2012 | 11:18 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
Originally Posted by creteangel78
mine has back fired, rattled inside the exhaust, i kicked it and bent it in now its fine...I did find a vaccuum hose unpluged in the upper drivers side! short hose bout 6-7 inches sucking air in, cant find where it goes its attached to three other hoses that are hooked else where, but this one have no clue where it should be plugged into??? put a screw in the end of that hose and the motor idles down a few notches!!! I replaced wires and plugs it seems not to be missing any more and when it first starts up it dont put and spit, its running on all cylinders now..This hose is going to bother me, suck air in or not?
Hose is plugged into a lil spout in the femder side wall. Look under a box. The spout is resessed a lil
meatbag
Sep 24, 2012 10:26 PM
mikol23
29
May 13, 2010 02:49 PM
KLBlazer07
Mar 23, 2007 01:42 AM
SDimeBlazerlady
Sep 17, 2006 05:43 PM
CruisinCarAudio
Jul 2, 2006 01:16 PM
