2000 blazer lift help!!!!
RE: 2000 blazer lift help!!!!
yup, i already have the shackles and now i am just waiting on the wheels and tires. i am going with soft 8 16" with a 5" backspacing. and i am going with 265/75r16 cooper st.
so if i get a 2" BL an 31" tires on a stock blazer..will it have good clearance??
like will there be much rubbing
I was told before that cranking to torsion bar to lift ur ride height created front end ware, or is that why u stated 1.5" max? If I purchased a 2" body kit plus the shackles and cranked the torsion bar 1.5", how much would the ride quality change? So with the 2" BL and 2" SL i should be able to run on 31 x 10.5's without needing to regear or trim right?
And the tires i mentioned before are 33 x 10.5's and are buried under a ton of snow.
ORIGINAL: B chevy99
If i were to used 2" shackles on the back and crank the T-Bar 1.5" would it not slope to the front quite a bit?
yes, that is correct.
with the the 2"sl and 2"bl, u should be able to clear 32 with minner triming. 33 with more trimming. there are a few ppl running 33 with that kind of lift on here. depending on what size tire you are running, plus the lift you are adding, you will probably get 4" of total lift in the front.
36's with no trimming, its going to cost alote trust me
http://i496.photobucket.com/albums/r.../blazer001.jpg
Just my 2 cents...
Add-a-leafs > Shackles
31's are OK as is
32's regear
33's Play easy- axles recomended
35s axles required
31's are OK as is
32's regear
35s axles required
Nice thing about shackles is they really do not mess with your ride quality all that much.
COUNTRYBOY061488
08-28-2008 07:54 PM
