body lift questions
Old Mar 11, 2009 | 10:27 AM
jeffreys25's Avatar
jeffreys25 is an unknown quantity at this point
Default body lift questions
How hard is it to install a body lift into a 2001 Blazer, and what sort of things should i look for before purchasing and attempting to install the body lift
Old Mar 11, 2009 | 03:02 PM
ShockGuys's Avatar
Banned
ShockGuys is an unknown quantity at this point
Default Body Lift Question
Jeffrey,
There are several factors initially to consider - is your vehicle a 2wd or 4wd, manual or auto and how high of a lift kit you are looking to install.
Here's a pretty good article on the subject - http://ezinearticles.com/?Installing...Kits&id=591409. Installation steps 1 - http://www.stylintrucks.com/Articles...1/Article.aspx and 2 - http://www.stylintrucks.com/Articles...2/Article.aspx.
Anything over 2" you won't be able to use stock shocks or stock shock height.
We don't sell lift kits but certainly can supply you with shocks for either needs (stock or 2"+ heights). Here's some info on our sites about lifted trucks as well - http://www.shockwarehouse.com/news/lifted-trucks.cfm.
Feel free to contact me if you have any questions.
Old Mar 11, 2009 | 04:12 PM
jeffreys25's Avatar
My blazer is a 2dr 4wd 4.6L V6 and its a 5 speed
Old Mar 12, 2009 | 12:12 AM
AJBert's Avatar
First thing to do, regardless of if you use the PA kit, download the BDS instructions from their website. Much easier to follow and better pictures. Read, reread and the read them once again. Find everything that needs to be down on your vehicle BEFORE you start. This will make things much easier and quicker.
Second, depending on where you live, start spraying body mount bolts and everything else with PB Blaster or your choice of penetrating oil. This will result in less headaches when wrenching time comes around.
Third, if you don't have air tools, FIND A BUDDY WHO DOES!!! This will cut the install time in half. It can be done with hand tools but much nicer to have the air tools.
Fourth, make sure you have all the tools you'll need. A lift is best, a floor jack better. Make sure you have a few blocks of wood, preferably 4X4 about a foot long or so. Makes lifting the body off the frame much easier.
Fifth, take your time, follow each step in the instructions, and don't rush when you get close to being done.
brino1
Dec 16, 2009 04:17 PM
dalifts
Lifting Tech
16
Feb 27, 2009 05:28 PM
jdcool4
Lifting Tech
Feb 7, 2009 02:45 PM
peckboy
Lifting Tech
Nov 20, 2008 07:51 PM
tjwiens91@hotmail.co
Lifting Tech
Jul 10, 2008 11:21 PM
