How much would a 2inch shackle lift effect gas milage? and other ?'s about the lift
Old Feb 7, 2010 | 12:10 PM
ohsofly's Avatar
Coil spacers eh? Ive never heard of those. I imagine they go on the bottom or top of the springs though. When I put the Belltech springs in my kid brothers truck, we had a hard enough time getting them in and had to use a spring compressor on the motor side to make them curve enough to get the lower arm jacked up without the spring popping out. I can imagine what kind of a nightmare its going to be with a stock spring with another 2 inch spacer on it... I dont have any advice on getting that one put back together except if its not goin in to take the contol arm off the frame too and jack it up straight and fasten the control arm on the frame and balljoint that way... That front suspentions going to be rock hard with the spring under another 2 inches of load all the time.
Old Feb 7, 2010 | 12:29 PM
NVANZEE's Avatar
I helped my buddy put some on his trailblazer and there werent too bad
Old Mar 4, 2010 | 12:22 PM
demoniac's Avatar
demoniac is on a distinguished road
Originally Posted by NVANZEE
4.It will go down slightly, maybe .5-1mpg just because you will be higher up and pushing slightly more air.
lmao.....so your telling me there is more air up there....lmao...
sorry dude i gota give you crap on that one ...thats just the crazyest shiznit ive ever heard anyone ever say...lmao......
Old Mar 4, 2010 | 07:18 PM
Phil's Avatar
Hey new guy, nvanzee knows what he is talking about.
Think about it- lets say for example a vehicle sits 2 feet off the ground, is 7 feet long, and 4 feet wide (just throwing out random numbers). So we have essentially a box with a certain Volume of air underneath it. Volume is the amount of something a shape can hold. Volume of a box = LxWxH. 7x4x2 = 56ft cubed.
Now raise it 2 inches. [2 ft + 2 inches (out of twelve to make a foot) = 2 & 2/12, put in the simplist form is 2 & 1/6. So our new numbers are Volume = 7x4x2.166 = 60.66ft cubed.
60.66 > 56. So yeah, nvanzee is right. Numbers don't lie.
EDIT: Forgot to add- more air under the car = more drag = worse MPG.
Old Mar 5, 2010 | 07:28 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
you probably wont notice much, if any gas mileage difference. Larger tires normally kill your mpg worse than lifts. Its the increased rolling resistance of larger tires. 235's arent much bigger than the stock options for your vehicle to begin with. As for the post about aerodynamics, and air volume and such, that makes a big difference when you are dealing with vehicles that are designed with aerodynamics in mind. Im pretty sure that was far from the minds of the creators of the chevy blazer.
TheSnowGoose
Lifting Tech
Oct 12, 2014 02:41 PM
king22
The Chop Shop
Aug 2, 2009 12:04 PM
burningsun
15
Jun 2, 2009 06:00 PM
jessebasiuk
Oct 4, 2008 08:39 AM
Dhurteau
Lifting Tech
38
Nov 21, 2007 10:15 PM
