Lift
Old Mar 1, 2019 | 12:15 PM
Santii524's Avatar
Santii524 is on a distinguished road
Default Lift
I have 98 blazer I want to try 5 in blocks in the back but what can I use to lift the front about the same
Old Mar 1, 2019 | 12:37 PM
People have done 6" lifts but for the front, anything over about 2" requires a relocation of the front axle or a swap to a solid axle.
Check out this thread: https://blazerforum.com/forum/off-ro...-6-lift-98372/
Old Mar 1, 2019 | 12:42 PM
Santii524's Avatar
The thing is my rwd
Old Mar 1, 2019 | 02:14 PM
cleburne red's Avatar
You're gonna have to do an axle flip in the back, the axle is above the leafs.
Why are you trying to lift a 2wd truck, though?
Rough country makes a 2" lift for 2wd trucks. New coils, and a add a leaf for the rear
Old Mar 1, 2019 | 04:15 PM
I think wether 2wd or 4wd, you would have to relocate the control arms above 2-3 inches...
dont quote me...
but I'm thinking that theres not more then 3" from center of spindle to bottom ball joint. I guess you can add spacers, but itll suck in your front stance by the time you get your height. Let alone screw the angle of your ball joints...
you could jack the rear 5", and then do a rc 2.5 lift on the front to give you a hot rod look(pretty sure mines like that unintentionaly).
Old Mar 1, 2019 | 05:26 PM
Yeah, anymore than like a 2.5" lift is gonna take drop brackets for the control arms. Can always go with a body lift, also, if you're just wanting the look
S10BlazerFTW
Oct 22, 2013 04:22 PM
stevemccalister
Lifting Tech
Nov 26, 2012 02:24 PM
CUrules
Lifting Tech
Aug 22, 2008 12:01 AM
fla_blazer4x4
Lifting Tech
Mar 16, 2008 12:54 PM
richlo
Suspension Tech
Oct 28, 2006 06:30 PM
