lifting a 96 2wd blazer
Old Mar 29, 2011 | 09:33 PM
ilovedonuts13's Avatar
ilovedonuts13 is on a distinguished road
Default lifting a 96 2wd blazer
i know there's other posts about this but all the details are mixed between years and what not so i just need some straight answers...
I want to lift my 96 2wd blazer 2 inches and id rather not go with a body lift, so can anyone give me a link for shackles?
Or any ideas for lifting the front?
and will 265/70/15 fit with a 2' lift?
anything helps, thank you
Old Mar 30, 2011 | 06:48 PM
abig84's Avatar
i just installed a fabtech 2-3 inch suspension lift kit today at work on a 99 s10 blazer, it was basically upper control arms, torsion bar keys and rear shackles.
measured before and after got 1.75 inches outt the rear and 2.75 out of the front, truck does sit level. no idea on the tires though. customer picked it up with the stock tires still on it.
i googled around and i cant even find that kit anywhere
this is basically the same kit
http://cgi.ebay.com/ebaymotors/83-03...Q5fAccessories
Old Mar 30, 2011 | 07:23 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
heres one thats for a 2wd thats only a 2" lift
Rough Country Suspension Suspension Lift Kit - JCWhitney
Old Apr 1, 2011 | 11:04 PM
avelate63's Avatar
avelate63 is on a distinguished road
the first one obviously won't work cuz 2wd suspension does not have torsion bars.
i might be wrong but that 2wd drive kit will not work in the rear unless you flip your axle below the leafs ((which will get you about 2 to 3" anyway)) cuz it uses those blocks that only work when the axle is below the leafs. works for the front. or can always be cheap and get coil boosters (prob what i'm gonna do ha)
01blazer16
Lifting Tech
Aug 13, 2013 10:00 AM
WhiteKnight2000
Lifting Tech
May 14, 2010 04:28 AM
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
Blazin01
Lifting Tech
Jan 19, 2009 01:43 AM
pfcmooney
Nov 8, 2007 04:15 PM
