looking for a lift
Old Mar 13, 2012 | 04:35 PM
TURBO's Avatar
TURBO is on a distinguished road
Default looking for a lift
i have a 2000 4 door 2wd blazer im looking for a good 4'' or 5'' suspension lift... any suggestions?
Old Mar 13, 2012 | 05:05 PM
warthogdriver's Avatar
i have a bds 5" lift kit in.
it went in pretty good...my only complaint is finish doesnt hold up well.
but all in all...happy camper.
Old Mar 14, 2012 | 01:41 PM
xgiovannix12's Avatar
did you ever fix that with the tack welds wart?
Old Mar 14, 2012 | 02:55 PM
actually at the time and wind chill...i used double nuts to do the job.
with the nicer weather i will be looking for the better fix soon.
Old Mar 14, 2012 | 03:01 PM
ahh got ya I think the tack welds are the way togo with these kits
Ive seen many users of this kit do that
Old Mar 14, 2012 | 09:41 PM
Rottidog's Avatar
Originally Posted by TURBO
i have a 2000 4 door 2wd blazer I'm looking for a good 4'' or 5'' suspension lift... any suggestions?
Try "Search" in here, look around, check out what other people have done & their opinions. There's tons of info & 1st hand use/knowledge.
Old May 15, 2012 | 03:03 PM
throwinrox's Avatar
throwinrox is on a distinguished road
Turbo is looking for info on lifting his 2WD blazer. I think you guys are talking about a 4wd lift..
My son has a 2WD Jimmy. I installed the MOOG 2" coils and that brought the front up just above level with the rear. I just purchased 2000 s10 lift spindles and 2" lift shackles for the rear. Because the Jimmy is a dual piston caliper and the s10 is a single piston you have to use the s10 calipers and rotors. Luckily mine came with these parts. I will have to have a longer brake line made with s10 banjo on one end and Jimmy fitting on the hardline end as the s10 and jimmy lines are not interchangable, it will be @ $70 for the lines. I hope this helps you out Turbo
dougg01
Lifting Tech
19
Jan 21, 2010 02:48 PM
96BlazerGrrrl96
Nov 11, 2009 10:58 AM
RJH8541
Nov 8, 2007 11:25 PM
Matty Kling
Feb 3, 2007 12:21 PM
Blazinchevy01
Nov 21, 2006 11:19 PM
