need help with a 2inc rear lift.
Old Jan 9, 2011 | 07:24 PM
97zr2's Avatar
97zr2 is on a distinguished road
Default need help with a 2inc rear lift.
Hello a have a 97 zr2, blazer i have just ordered the 2 inch torsiom keys offline, to get 2 inches out of the front of my blazer. but i also need 2 in the back, i know that blocks will actually lower, im not a big fan of add a leafs, and i was looking into shackles, and i know whatever i add i will only get half right?
so i would need 4 inch drop shackles for a 2 inch rear lift correct?
and will i need new shocks all around?
Old Jan 23, 2011 | 09:29 PM
zr2dan's Avatar
zr2dan is on a distinguished road
i changed my shackles and bushings with a set of shackles that where 2 inches longer than stock and put the super lift add a leaf and it leveled me up nice with a 1.5 t bar crank in the front ang let me tell you there is nothin easy about swapping the shackles you will trash your bushing so make sure you buy new ones and shackle bolts get those too and when you get your 2 inches in the back your stock shocks will have to go because they will bottom out i spent about 200 bucks lifting my rear end and alot of hours doing the work if you search through the forum there are pics of shackle swaps as this is a common thread
Tommyboy8299
Lifting Tech
Jan 26, 2013 10:39 AM
kreep_66
14
Apr 25, 2012 09:48 AM
ewodonnell
Suspension Tech
Apr 24, 2012 12:46 AM
tri94bbc
May 6, 2011 10:22 PM
Kemp
Jan 27, 2010 05:45 PM
