sfa questions
Old May 24, 2010 | 02:00 PM
s10 blazer dude's Avatar
s10 blazer dude is an unknown quantity at this point
Default sfa questions
im thinking about doing solid axle swap n my 94 s10 blazer, my buddy is giving me front and rear axles the rear is a 12 bolt, and the front is a dana 44, thats all that he is giving me. if i go through with it, i would like to fit 35's so im just curious if anyone knows the best combo of parts or set up ,,like what size leaf springs, what to switch the steering to etc. also im curious if i do the swap, for 35's should i leave the 4.3, or should i get 305 or 350 so i can actually move when its finished...thanks
Old May 24, 2010 | 04:50 PM
abig84's Avatar
What gears are in the axles? I'm running 33s with 373s and a 4.3 and its about perfect. But I had a 2.8 s10 on 35s and it got me around. For steering the cheep easy way is get a astrovan box and a flat top kunuckle for the passenger side to bolt a steering arm too.
For my lift I did a spring over axle with a 4 inch block outback and 4 inch k5 blazer lift springs up front. That amount of lift might work if you don't mind trimming the fenders.
Old May 24, 2010 | 06:06 PM
the rear has locked 3.73's and i believe it was 4.11's up front but im not sure, i havnt picked up the axles yet, thanks for the help
Old May 24, 2010 | 07:12 PM
abig84's Avatar
If those gears don't match you won't be able to use 4x4 unless in really low traction areas
Logan
Suspension Tech
Dec 16, 2009 09:50 PM
wlorton
Lifting Tech
Dec 4, 2009 09:08 AM
Logan
Lifting Tech
Aug 21, 2009 09:30 AM
fst450
Sep 22, 2008 05:19 PM
96Superflow
Aug 26, 2008 09:09 PM
