sfa guys
Old Sep 14, 2008 | 10:11 AM
fst450's Avatar
fst450 is an unknown quantity at this point
Default sfa guys
Im preparing to do a sfa swap just have a few questions... doing a spring over in the rear how many inches will that gain? How does the front driveshaft come out of the t case? And also i see alot of sfa guys doing away with all sway bars on there straight axels? anyone have some pointers?? thanks a bunch!
[IMG]local://upfiles/9846/611752D9845240828B98B4A8E67D45D9.jpg[/IMG]
Old Sep 22, 2008 | 11:47 AM
bad350v8s10tahoe's Avatar
bad350v8s10tahoe is an unknown quantity at this point
Default RE: sfa guys
spring over will give you 4+ inches without blocks, i wouldnt run sway bars either if you spend alot of time off road. not sure about the front driveshaft but i would think it just bolts on with the u-joint u bolts
Old Sep 22, 2008 | 12:18 PM
WolfPack's Avatar
I wouldn't get rid of your sway bars unless you plan to trailer it everywhere. The sway bar limits your articulation, which is the opposite of what youd be gaining with the SFA/SOA. If you want to have it streetable and offroad ready, make some sway bar disconnects. Although if you go with a Dana axle, there will already be aftermarket sway bar quick disconnects out there for your new sway bar. You'll just have to custom mount it to the body...but that wouldn't be much since you custom fabbing your front end
Old Sep 22, 2008 | 12:23 PM
Actually, if you are going to drive it on the road at all, I would recommend keeping the sway bar and getting longer quick disconnects for it. With the change in center of gravity, anti-sway bars will be even more beneficial to keeping the truck controllable at regular highway speeds.
LMAO! That is what I get for writing a post before lunch, then submitting it after!! Great minds think alike!
Old Sep 22, 2008 | 05:19 PM
fst450's Avatar
Thanks guys!
Logan
Suspension Tech
Dec 16, 2009 09:50 PM
wlorton
Lifting Tech
Dec 4, 2009 09:08 AM
Logan
Lifting Tech
Aug 21, 2009 09:30 AM
fst450
Mar 11, 2009 05:01 AM
96Superflow
Aug 26, 2008 09:09 PM
