SFA Conversion
Old Jun 28, 2008 | 04:57 PM
96Superflow's Avatar
96Superflow is an unknown quantity at this point
Default SFA Conversion
Ok i know this topic comes up all the time and i have read past posts on it, but they always seem to leave me wanting to know more about them. I am finally retiring my 1996 4dr as my DD, and im looking at keeping it as a project. I have been thinking about doing this conversion, but never seriously pondered it until now. I just recently saw in a petersan's 4 wheel and off road mag a swap of the factory rubicon axles that can be purchased right through your dodge dealership into i think an XJ or Grand Cherrokee (probably the same thing but i dont memorize heep ****), and since they come as D44 axles, driver side drop, 4.10 gears and electric lockers all for 1400 bucks a peice (they have both front and rear), im starting to save my cash. I drooling over the thought of a SFA in my blazer. I would like to keep it streetable witha maximum of about 35's, but i want a coil-front suspension. I remember reading it somewhere that someone is enginerring a bolt in kit which is awesome.This vehicle has been promised to my 2yr old nephew, so i need to get it finished so i can have some time to wheel it and start pulling out my buddies 1995 heep. haha any information or a point in the right direction would be a great help. thanks
Old Jun 28, 2008 | 08:04 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Default RE: SFA Conversion
Try searching over on www.s10forum.com There are a lot of members over there that have SFA trucks and a lot of good info on how to over there. Thats where I've got most my info on the swap.
Old Aug 22, 2008 | 05:12 PM
crewchief888's Avatar
crewchief888 is an unknown quantity at this point
i haqvent sen anyone thats done a coil spring swap as yet, but theres a lot of leaf spring swaps out there. i'm planning on doing a leaf spring swap this winter using axles out of a 87 wrangler. found some decent pics of the front crossmember from this guy
S-Series.Org :: View topic - Solid axle swap Mini MOnster underway with the V to the 8
ive look ata friends TJ and doing a coil spring swap looks like a royal pain, not only do you need the spring mounts you'll have to fabricate trailing arm mounts ect. take a look under a late 90's tj and you'll see what's involved.
good luck [8D]
Old Aug 25, 2008 | 12:37 AM
Verno's Avatar
Verno will become famous soon enough
My ZR2 will have a SFA soon, coil spring swap, getting the D44 Rubicon axle, cant wait till it's finished.
Old Aug 26, 2008 | 09:09 PM
hey verno, just saw you're from Ft wayne, i'm over in NW indiana.
just got back from my shop a while ago, just pulled the front diff housing outta my blazer, (thinking i just had a bad bearing), but found broken spider gears, broken side gears, chipped ring and pinion , and a cracked /broken LH case
already have a line up on a wrecked blazer that a friend wants the engine out of, so maybe i'll snag the diff housing and toss it back in mine if all else fails, everthing will get welded back up, the case packed with grease, and hope it holds together for one more trip to the Badlands before the weather turns.
talk later
Logan
Suspension Tech
Dec 16, 2009 09:50 PM
wlorton
Lifting Tech
Dec 4, 2009 09:08 AM
Logan
Lifting Tech
Aug 21, 2009 09:30 AM
fst450
Mar 11, 2009 05:01 AM
fst450
Sep 22, 2008 05:19 PM
