need help with shackle install
Old May 15, 2011 | 10:59 AM
Charder's Avatar
Charder is on a distinguished road
Default need help with shackle install
anybody in the central jersey area wanna install my shackles for me? i can not get the bolts outs of the bushings!! it took me and a buddy almost 5 hours to get the bolts and bushing out of the leaf springs but then i ran out of time so i had to install the new bushings in the old leaf springs to drive home. and i dont feel like even trying to get the bolts and bushings out of the frame
Old May 15, 2011 | 12:23 PM
Digital Daze's Avatar
Digital Daze is on a distinguished road
The ones on the frame were a lot easier than the ones on the springs. Sounds like you got the hard part done already!
Old May 16, 2011 | 08:35 AM
Charder's Avatar
they dont seem any easier... the bolts are just as stuck and seized in the bushing as the ones in the springs were. but the ones in the frame seem in a more difficult spot to press the bolts out
Old May 17, 2011 | 02:24 AM
If you were closer I would give you a hand. I hope you get them out.
Old May 17, 2011 | 09:39 AM
Rottidog's Avatar
Have you looked at https://blazerforum.com/forum/articl...-thread-43925/
It's a pretty informative write-up.
Old May 17, 2011 | 04:46 PM
Charder's Avatar
ive read that write up a dozen times and a few others a couple times i still cant get those damn bolts out... well i havent tried again since due to work. hopefully ill get back out there this weekend depending on weather
Old May 17, 2011 | 06:18 PM
rob44_90's Avatar
rob44_90 is on a distinguished road
I had the same problem. If you have an air hammer, that will knock them right out!!
Old May 24, 2011 | 07:58 PM
Charder's Avatar
ok i give up!! ive tried every tool possible in my garage and 3 of my buddies garages and i cant get these damn bolts or bushings out. where can i take it to get done for me for a resonable price. i have new bushings and new bolts and obvisiously new lift shackles
Old May 25, 2011 | 10:27 PM
mdehoogh's Avatar
I dont know what to tell you man. Mine came out by hand the same as any other bolt. I was mildly disappointed after reading so many reports of people having trouble. Have you tried an air hammer/chisel? I would think any mechanic would be able to somehow remove the stuck bolt but if you've already tried most options, there may not be much that they can do...
Old May 26, 2011 | 07:26 PM
beatupjimmy's Avatar
beatupjimmy is on a distinguished road
PB Blaster and a propane torch. If that doesn't work, use a cut-off wheel on an angle grinder and chop both ends off.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
DreezyBeezy
Lifting Tech
May 27, 2012 01:11 AM
btmbass
Lifting Tech
Sep 18, 2011 10:12 PM
BlazerGuy2001
Lifting Tech
13
Feb 20, 2010 03:55 PM
greenlantern77
Jun 12, 2008 05:06 PM
