Starting a SFA project
Old Dec 23, 2010 | 10:12 PM
mov4x4's Avatar
mov4x4 is on a distinguished road
That I'm unsure of but I would assume that it doesn't matter. But you know what they say when you assume things it makes an "***" of yo"u" and "me"
Old Dec 25, 2010 | 10:00 PM
POWERSTROKEN's Avatar
POWERSTROKEN is on a distinguished road
Thank you for the link. In a week of searching I have come up with a ton of vague threads but no real insite until today. Jim
Old Dec 26, 2010 | 01:07 AM
mov4x4's Avatar
If your looking for a "sas" thread I know there's a good one on s10forum.com the guy made a 2wd s10 in to a straight axel 4x4. Or try prite4x4.com
Old Dec 26, 2010 | 01:28 PM
ABN31B's Avatar
Yer welcome.
Old Dec 27, 2010 | 08:54 AM
skotti's Avatar
skotti will become famous soon enough
Another great site for sfa is http://s10extremist.org/ Tons of info.
there is a bolt in front crossmember https://www.4wdfactory.com/store/pro...sion-%284wd%29 there will still be welding involved so get comfortable with it, or find someone that knows what there doing.
Alot of ppl also use a front mount hitch with leaf perches welded on. Keep researching it though. theres alot of different ways and alot to consider. I plan on starting mine in the spring time.
Old Dec 28, 2010 | 12:30 AM
mov4x4's Avatar
I have read this one a couple times and learned more each time I read it... http://www.s10forum.com/forum/f222/m...e-pics-295223/
Old Dec 28, 2010 | 05:11 PM
Logan's Avatar
Logan is on a distinguished road
Bronco, TJ, YJ axles if you dont have fender flairs
XJ, ZJ, Wagoneer axles if you have flairs...ie ZR2's
89-94 Astro van steering box ( this swings the pitman arm 180 degrees, facing front instead of towards the rear )
Pitman arm...
Dana 44 axles need a wagoneer pitman arm
Dana 30 needs TJ/YJ/XJ/ZJ pitman arm
Wagoneer front leafs or rancho part #44044 are leafs of choice
I used super lift 6" lift shocks.
Someone posted a bolt in kit for around $450. Dont remember the name, but that would be the way to go for the front axle. I got a guy on www.ovo.ca to build me all my brackets.
I made my front cross member out of 3'x2"x4"x3/16" steel tubing.
Rear brake hose off a 1996 Dakota, Front hoses off a 1995 Chevy C1500
Rear drive shaft I took a1991 Blazer, and had it shortened to fit. Front drive shaft fromt a 4l auto XJ. That requires the t-case 27 spline front output yoke if you go with a NP-231 swap.
Do not go ubolt eliminators in the front unless you want 8" of lift.
Anymore questions, pm, email preluderacing909 (at) hotmail.com
Old Mar 28, 2011 | 07:59 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
@Logan....Any pics of the completed lift and any tips for those that are thinking of tackling the project?
Old Mar 28, 2011 | 08:12 PM
I'm on my way. I've got the 44044 springs, Sky X member, Astro van box. This will go good with my built Toy axles, and marlin crawler dual ultimate Toy t cases. Thanks for the info. Jim
Logan
Suspension Tech
Dec 16, 2009 09:50 PM
wlorton
Lifting Tech
Dec 4, 2009 09:08 AM
Logan
Lifting Tech
Aug 21, 2009 09:30 AM
fst450
Sep 22, 2008 05:19 PM
96Superflow
Aug 26, 2008 09:09 PM
