thinking of a 2in lift
Old Sep 21, 2007 | 08:30 AM
schums's Avatar
schums is an unknown quantity at this point
Default thinking of a 2in lift
I have a 96 Jimmy 4-doorSLS I am thinking of puting a 2in lift in it the only thing is I just got new tires, 235 General Grabbers AT2 on the stock rims. The question I have is will it look alright with the 235s or trade them in and get some bigger ones?
Old Sep 21, 2007 | 09:27 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: thinking of a 2in lift
to be completely honest, a 2inch lift isn't worth the money unless you are just going for looks.... you can only fit 31's which are less than 1 inch height difference from your current tires..... if you want a more aggressive look, consider leveling the truck out with a torsion bar crank..
Old Sep 21, 2007 | 11:22 AM
schums's Avatar
I was thinking of the crank though my back end saggs some, i believe i need my leaf spring resprung or whatever it is. When i bought the Jimmy it had 30.5 tires, some cheap brand that road like crap. The reason i was thinking about the lift is my back end sits low then i have a receiver hitch which makes it look like it sits even lower. Any ideas of how to level the back end and make it look good maybe? Thanks for the input
Old Sep 21, 2007 | 06:19 PM
a_tack's Avatar
shackles, add-a-leafs, or air shocks(not the best option)..... a 2 inch suspension lift kit really is just a glorified TB crank and some shackles..
Old Sep 21, 2007 | 07:58 PM
schums's Avatar
Haha alright that works
hypedave
Lifting Tech
26
Apr 23, 2016 12:39 PM
98jblaze
Lifting Tech
Apr 1, 2010 09:45 PM
jdcool4
Lifting Tech
Feb 7, 2009 02:45 PM
94camaro
Lifting Tech
Dec 15, 2008 08:45 PM
Nazdreg
Lifting Tech
Apr 3, 2008 07:02 PM
