torsion bar
Old Sep 29, 2008 | 09:55 AM
blazin 4.3's Avatar
blazin 4.3 is an unknown quantity at this point
Default torsion bar
I have a ? about lifting my 98 blazer i know how to lift the rear easy but i just dont know an easy way to lift the front of my blazer... i want to go for at least a couple inches, but is tightening the torsion bars the only way to lift the front???? thanks!!!!
Old Sep 29, 2008 | 12:58 PM
hookem07's Avatar
hookem07 is an unknown quantity at this point
Default RE: torsion bar
If youre using shackles in the back then yes. you could always go with a body lift kit from performance accessories (frame spacers).It would take more effort/money to do but it wont wear out your front end as much as cranking your t bar.
Old Sep 29, 2008 | 02:13 PM
Blazin NC's Avatar
Blazin NC is an unknown quantity at this point
The other option is to get new torsion keys, that way you don't have to crank as much as your ride stays smoother.
Old Sep 29, 2008 | 03:19 PM
Keys just relocate the point which the adjustment bolt hits. It does not correct anything with how "wound" the torsion bars are or any of the ride harshness as those things are only changed by moving parts around on the other end ($$$).
azzr2
Mar 25, 2012 04:19 PM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Mbastet99
Nov 7, 2006 07:52 PM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
