Torsion Questions
Old May 2, 2008 | 09:19 PM
Default RE: Torsion Questions
Didn't I already say this...? Weak torsion bar. You could try to find used bars on eBay or a local junkyard for cheaper than new, but you may run into the same problem.
Old May 2, 2008 | 09:25 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
so what your sayin is that unless i wanna cough up 400 bucks that the only way i can make it level is with a lift kits.
Old May 2, 2008 | 09:40 PM
TripleBlackBlazer's Avatar
A lift kit will still use your stock torsion bar (I believe), those with the 5" and 6" kits please chime in if I'm incorrect. I know it's frustrating, but take the time to read the responses that people have taken the time to provide you with.
A torsion bar sags and fails just like a regular spring/shock. Unfortunately, they are spendy (as was already mentioned). It was also previously suggested to get a spare (or two depending on cash flow) from a junkyard. They may still sag but at least it'll be cheaper than the $400 for a new torsion bar!
Old May 2, 2008 | 09:45 PM
ORIGINAL: tjwiens91@hotmail.co
Don't know where you got that from... I suggested the possibility of getting a used set from a truck at a junkyard, not a lift kit. You could probably find a relatively new, low mileage donor at a junk yard. They'd be much cheaper than new.
The torsion bar would still be weak if used in combination with a lift kit.
And yes, just like any other spring, they are subject to fatigue and weaken over time.
megaroos_00
Lifting Tech
Feb 27, 2011 11:13 PM
Moores12345
Lifting Tech
23
Jan 6, 2011 04:36 PM
cage47
Nov 17, 2010 10:40 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
ChevyRacing88
Lifting Tech
29
Mar 29, 2008 12:47 PM
