what would this do
Old 08-21-2008, 11:26 PM
CUrules's Avatar
CUrules is an unknown quantity at this point
Default what would this do
does this mean a 4inch lift
http://cgi.ebay.com/ebaymotors/88-06...9424QQtcZphoto
Old 08-21-2008, 11:50 PM
WolfPack's Avatar
Default RE: what would this do
It would give you 4' of lift if you had the right application..
A block lift only works if the leaf springs are above the axle. S-series blazers, the leaf packs are below the axles. So...if you were to install that on your truck, you would drop it 4', not lift it.
Even if that did work, you would still need a way to raise the front end 4' to match the back..which you cant do since you have IFS.
If you wanna lift that high, you have to do a spring over axle conversion (SOA) to get the leaf on top of the axle in the back (~5' of lift), then you would have to do a solid axle swap (SAS) up front, and then install that 4' block lift up front.
On top of all that....a block lift is not really the best way to lift a full size truck..anyway..
No.
Old 08-21-2008, 11:55 PM
CUrules's Avatar
ok thanks
Old 08-22-2008, 12:01 AM
WolfPack's Avatar
haha yep.
Blaize70
Nitrous, Super Chargers, & Turbos
19
09-20-2008 10:23 AM
Jhop16
Headers, Intake, & Exhaust
01-20-2006 03:30 AM
propellerhead
12-19-2005 03:20 PM
neogeo92
10-08-2005 03:19 AM
bigredchevyblazer
Suspension Tech
08-29-2005 03:26 PM
Quick Reply: what would this do
