2000 s10 4.3l pickup electrical fans not working
Old Jun 9, 2019 | 11:48 PM
Geeboss's Avatar
Geeboss is on a distinguished road
Default 2000 s10 4.3l pickup electrical fans not working
When I got the truck the regular cooling fan was replaced with electrical cooling fans and they do not work so at idle it overheats. I put 12 volts to the fans they came on. Also when the truck did over heat the fans did pop on. But they won't pop on until it overheats. I've replaced the CTS so far and nothing what else should I do? I was just thinking about hard wiring them. But I would rather have them work correctly.
Old Jun 10, 2019 | 07:44 PM
Since these trucks never came with electric cooling fans, you will likely need to do this troubleshooting yourself. Only you can determine what parts were installed & how they were hooked up. Follow the wiring from the fans and see if there is a control box with a manufacturer information on it.
Where was the CTS that you replaced? Most aftermarket fan control setups use a surface temperature probe on the radiator core itself.
Old Jun 10, 2019 | 11:34 PM
Geeboss's Avatar
The CTS was located driver side on the block. I'll dig in it some more tomorrow and look at the wiring more.
Old Jun 10, 2019 | 11:37 PM
Geeboss's Avatar
I thought it was weird that they popped on when it overheated but won't pop on to cool the motor before it overheats.
Old Jun 10, 2019 | 11:42 PM
If the coolant temperature switch you have is designed for a light, it may not come on until it's too late. What temperature is it rated to switch on at?
Old Jun 11, 2019 | 10:02 AM
Geeboss's Avatar
The coolant temp sensor is what I replaced. I just put a stock one on it.
Old Jun 12, 2019 | 05:16 AM
The temp sensor in the driver head is a variable resistor sensor, not a proper temp switch for tripping a relay to trigger a fan circuit.
Assuming the fan is activated via a relay, which it better be... you may be better off just having that relay triggered by an ignition source than the temp switch. Then whenever the engine is running, so is the fan, and you don't even have to worry about it.
Just my $0.02
Randy S. Hager
Jun 11, 2016 05:56 PM
Robt77
22
May 8, 2014 04:33 PM
mrd0t
Performance & Brainstorming
Jan 9, 2011 02:17 PM
FreshDA9
Feb 19, 2010 06:37 PM
cody32401
Nov 7, 2006 12:51 AM
