97Blazer fuel pump runs on
Probably the first thing to check is to see if there are any other vehicle systems that should run on ignition, but are coming on with Acc. If so, then likely your problem is in the ignition switch.
Believe it or not, I just purchased this vehicle a month ago. The previous owner owned it for about 12 years, in a farm setting. they did very little upkeep on anything that broke. So I changed the oil& filter and that cured the oil pressure switch from staying stuck. AND at the same time cured the fuel pump running in accessory position..
I agree with you that the oil pressure switch was the culprit. THANKS DAVE
billygoat
07-22-2011 08:37 PM
